While using Adobe Photoshop, I got an error due to a problem initializing cc libraries, existing links to library graphics will appear broken, and new link creation may fail. Can anyone explain this error?
Explain Due To A Problem Initializing Cc Libraries, Existing Links To Library Graphics Will Appear Broken, And New Link Creation May Fail. Failure
This problem indicates that your System is incapable for this software.
Every application has some fixed system requirements. Below that features, the tool will not work on that system.
Similarly, It also requires some predefined system capability. You can check the necessary features for the installation here.
It can be the problem of your Operating System. This tool runs on Windows 7 and higher version. Be sure your machine has the latest OS.
It seems there is a problem with your installation of Adobe Photoshop CC because it can’t initialize properly during startup. This normally happens if the application was started in an operating system that has insufficient resources or the system specifications of the program were not met. This makes the application incompatible with your computer even if you have a supported operating system.
Since you did not mention what version of Photoshop CC you have, here are the specifications. For Photoshop CC 2015, it supports Windows 7 Service Pack 1, Windows 8.1, and Windows 10. Windows Vista and earlier are not supported. If you have Microsoft Windows 8, you should update to Windows 8.1.
It requires 2 GHz or faster Intel Core 2 or equivalent AMD Athlon 64 processor, 2 GB RAM, 2.6 GB free space, 1024 x 768 screen resolution, and video card with 512 MB dedicated video RAM and OpenGL 2.0 support.
