naalagappan
Posted on - 06/24/2016
Hi, I have a question related to the mailing portal called outlook. I just started using it and I think it’s better than gmail. I just have a confusion related to the many calendars I have on it. Some of my calendars are shared with my buddies as well. What if I want to sync two exchange calendars? How can I do that? I am using a macbook pro.
p.dacey
Explain How To Sync Two Exchange Calendars.
I am going to teach you a very easy and efficient way to sync two exchange calendars! It requires you to use an add-in, which is specially designed for icloud users. So, if you don’t have an icloud account, I suggest you set up that first.
Then, download and install the add-in called Code Two Sync. It will allow you to sync all your calendars and other contacts and files, thus saving time and energy. Also, it allows you to access all your calendars on all your apple devices.
