Explain How To Increase Remote Desktop Sessions In Windows 2008 On My Computer.
Asked By 120 points N/A Posted on -
I am currently using the Windows 10 operating system on my computer. I have installed the Windows Server 2008 on it. I want to connect some desktops to it. Can someone tell me how to increase remote desktop sessions in Windows 2008 on my Windows PC?
Answered By 0 points N/A #292916
The number of remote desktop connections that are allowed to your PC via Windows Server R2 is variable and can be manually set using preference settings available on the Windows Server dashboard.
It is ideal to restrict the number of simultaneous connections, since it helps to improve the performance and speed of the system. Go to the Windows server settings. In the menu, search for an input tab named ‘Remote desktop connection.’ There must be a number written besides it specifying the number of connection which is allocated currently. You can input a number larger than this to increase the number of connections.
