A few days ago I wanted to set up a FTP server from my PC at home. I did some research, read a bunch of stuff but still couldn't figure it out. I wanted to share some files on the server, and also users to be able to get those files. I hope you understand what I mean. What I want, is for you to help me and explain to me how to use Golden FTP Server with step by step instructions if possible.
Explain how to use Golden FTP Server at home
Golden FTP server is free FTP server that you can set up at your home PC. After downloading Golden FTP server on your PC you need to decide the directories on your system that you want to access through FTP server.
Open Shares > Add > Add Share Folder Dialog > Add Directory > OK
On selecting directory, a window will appear showing IP address of server which you have to add:
Start > Run > Enter IP address
A window will appear showing your directory folders
