zenith keen
30 points
Posted on - 08/31/2012
Hi Experts,
I am having a hp notebook.I am looking for hp notebook keyboard commands.Does anyone know how use hp notebook commands.It would be better if there is video tutorial.Send me the link.Thanks.
Zenith Keen
Explain me on hp notebook keyboard commands ?
Following is a link where you will find many shortcuts for HP keyboards.
http://www.blogigo.de/
Most of the keyboard shortcuts which are related to Windows are same for all notebooks, laptops and desktops. You might find an Fn key on your notebook which you can press that in combination with others to perform specific tasks. On different keys you will find some symbols representing the functions like a battery symbol. So if you press that button while holding Fn, you will open up Battery settings!!
Hope this helps!
