Hello expert, I’m using windows 7 on my PC. I have to do an idle backup of my windows. I had downloaded idle backup 1.17 for preparing this work. Is it OK or can you explain me windows backup idle best way to do this work?
Explain me windows backup idle best way
Hello Laki Shafyffe,
If you are using Windows 7will give you a thorough system of your file back up. You can use it more conveniently and efficiently back up your files and improve chances of successful recovery. For this purpose you have to go to start programs, right click on computer and click on properties. You can click on system protection on the left hand side of opening window and can allocate disk space and define system restore setting by clicking on configure button and can create restore points by clicking on create button on the same dialogue box.
Hope it would help you in a better way.
Randle Steve
