Explain One Note Needs To Set Itself Up Before You Can Send To It Error
When I tried to take note in Microsoft One Note I get a message popup box “One Note needs to set itself up before you can send to it. ” How to resolve this fault?
Answered By 10 points N/A #288612
There may be several reasons why you are getting this failure. You can try below options.
  1. There is a repair tab available in every office utility. You just have to specify your problem and hand over that for the further troubleshooting.
6x
  1. If this flaw occurs while sharing the note, then use the spread option in the OneNote and create a shareable link. Share that link to spread. It will fix the problem.
