Explain The Expression Of The SSL Encryption
What does one mean by the term cybersecurity also explain the phrase cognitive cybersecurity? What does one mean by encryption, and why is it important? Explain the expression of the SSL encryption?
The term cybersecurity can be defined as a mixture of the different processes that guarantee the safety of a network and data from any unauthorized access that is in case the party accessing it does not have the required credentials. The term cognitive cybersecurity refers to the application of cybersecurity where artificial intelligence is programmed to work as a human to detect threats and protect data, data mining and pattern recognition are two applications of the same. Encryption is the process of converting the data into an unreadable format with the sole purpose of protecting it. SSL encryption is used so that it says connection can be established between two parties.
