Explanation And Significance Of Event ID 1309 ASP.NET
Consider a certain possibility of you upgrading your security in your windows software and while doing so you get message on your screen and a question in your head ‘what the hell?’Folks while you run a Microsoft ASP.NET 2.0 Web application you are likely to get an error coded as 1309.so what exactly is event id 1309 asp.net?
