Explanation Of Helpctr.exe Application Error
What is the helpctr.exe application error? Is this is a virus or malware? Describe the ways to fix this error?
Helpctr.exe application error is an error that is mainly a troubleshooting error occurs when windows help and support center doesn’t runs. Helpctr.exe are created by Microsoft Windows operating system. This software is usually about 4.85 MB in size.
The .exe extension tells that it is an executable file. To check it is a virus or malware, one should check the path of execution of this file, it should be run on the following path:
C:\windows\pchealth\helpctr\binaries\helpctr.exe and not anywhere else.
If this is not the path of execution, then it is harmful to systems you should delete it by installing security applications like Malwarebytes.
The ways to fix this error are that keep cleaning your hard disk and remove the unwanted application from your system. If the system is clean, then the error will not occur.
