Explanation Of HIPAA Compliant Email Hosting
The names and description of the hosts which provides HIPAA compliant email service are as follows:
It gives commercial-grade security since 2002. It provides HIPAA compliant email through a secure portal and Outlook integration. It’s a standalone application.
It can be opened through a secure portal that is compatible with mobile, and it has 24×7 customer support service.
It is mainly used by medical institutions to send mail to their patients. It has an easy setup to be installed and also gives 30 days free trial. The plans can be canceled any time, and it is compatible with any email providers.
It is completely HIPAA compliant enterprise solution. It gives the solution through video conferencing, messages, web hosting, and online forms. The plans start here with $50/months.
It provides HIPAA compliant email by directing the user to a secure portal where users can log on and file their complaints. It is very compatible with the service and easy to use.
It provides HIPAA compliant email through outlook and other select Windows application. It can be run by any device by going through a secure web portal. It is a mobile application with fingerprint security, and it gives 15 days free trial to users.
