fern bonnie
30 points
Posted on - 03/17/2013
HELLO !
I have a few questions of which I need detail answers so kindly explain briefly. What is the best software for flash spreadsheet creators ? Can I make flash cards with google spreadsheet ???
Explanation required for Flash spreadsheet creators
Hi Fern BonnieÂ
Yes you can make Flash cards with Google Docs . For that you first have to create a spreadsheet
Then put your text and contents in column A and B. Then after that you have to insert a gadget i.e. Flash Card gadget which is available in Google spreadsheet.
Go to Insert>Gadget
Now after that you have to fill in the Gadget setting Box in which you have to fill Range and type like this for ex:
Range – Sheet1!A:B and then click on Apply and Close.
ThanksÂ
Bennie
