Explore some easy to use tablet for seniors and the elderly people
Hi.
I want to buy an easy to use tablet for seniors for my grandparents. Can you please suggest me the tablets which are most suitable for them? Thanks in advance.
Hi.
Hi.
The options for some of the best easy to use tablet for seniors are as given below-
1) iPad Air 2: It is cheap and fit for use by the elderly. It can be purchased within the range of $400. It has a screen of 9.7 inches which makes it extremely suitable and easy to read. It provides a clear display, has a memory of 16GB and an excellent battery life.
2) Fire 10: This has been launched by Amazon. It is consistent and can be bought for a little higher than $200. It has a screen size of 10.1 inches which makes it suitable for people with a poor vision. Also, it has cheaper models available within $100.
3) Samsung Galaxy Tab A: This tab has 8 inches of screen with excellent clarity. It is lightweight and portable. It has a storage of 16 GB which makes it all the more attractive. It also provides the feature of Bluetooth. It is cheap and can be bought within $200.
Hope we helped.
Notifications
