Explorer View in SharePoint 2010
I am new to SharePoint 2010.
Just wanted to know where is the Explorer View found in SharePoint 2010?
Thanks and Regards
Pinu
Thanks and Regards
Pinu
Hello Pinu
If you want to upload documents to a SharePoint 2010 document library using the Explorer view, the process is different from SharePoint 2007. To find the Explorer view:
1. Go to your document library in SharePoint 2010. Click on the Library tab, then look for "Open with Explorer."
2. When you click on Open with Explorer, an Explorer window will open with the contents of the SharePoint folder.
3. Drag and drop documents from your PC into the SharePoint folder.
Hope that helps !
Kind Regards
Arseno
