Export data to excel problem
I was asked by the top management for some data on my search at the application we are using. All the required data is not available on one look. I must hop on every type of reports to arrived on the desired format that will be exported to. So I decided to just import data from Sybase to excel, on my exporting process an error occurred that I pasted below.
Microsoft Office Excel cannot use the number format you typed.
Try using one of the built-in number formats. On the format menu, click Cells, and then click the Number tab. Select the category you want, and then
Choose other options.
For more information about custom number formats, click Help.
On my analysis of this problem, it involves format of the data from Sybase going to excel. It seems excel will not accept it because of its format. Please help me find ways on formatting my data from Sybase to excel.
