Export document management software error and trace log
Hello Guys! I’ve experiencing this error using Document Management Software which is using .Net Framework. When I experience some error this image attached appear and ask if I want to export the log file. How can I use this log file to solve errors from my software? Any Idea?
Export FDA Logs
Which log file do you want to export?
errors.log
trace.log
