Exporting contacts from iPhones to computers
What are the steps to consider in transferring or exporting all of my contacts from my iPhone to my computer?
Is this possible even if my computer isn't an Apple product?
Hello
You can transfer or export all of your contacts from iPhone to PC by few ways. First, you need to connect your iPhone with your PC. After that start iTunes app and click on your iPhone. And last step for these way will be : go to contacts, from file menu chose export from file.
Other way for exporting contacts from iPhone to PC can be with sync them. You can do that by using Microsoft Outlook .Just full up “set up wizard “from Outlook. After that connect your iPhone with your PC and sync them. Now you can have your personal contact from iPhone to PC. Also with these you can have calendars and events from iPhone to PC.
Note: If your Pc is not Apple product you can still do these ways.
Hello!
There are a couple of steps you can try to transfer your contacts from your Iphone to your computer (even if it isn’t Mac).
First Option
You can try to download a program that would automatically copy your contacts from your iPhone to your pc. Check on the links below for more information about each program and for screenshots on how they work.
iMacSoft Iphone Contact to Pc Transfer
Tansee Iphone Transfer Contact
Second Option
Copy your contacts to your computer using iTunes.
Connect your phone to your computer then open iTunes and select your phone. Click on the "Info" tab; look for contacts then check box to sync with "Windows Address Book". On the drop down menu select "All Contacts" then click "Sync".
