Exporting image to Lumion exporter Can somebody shed some light
Hello everyone,
I am a student, and I am doing a project in which I want to export an image to Lumion in Revit 2012.
When I try to export my
desired image, I see an error on the screen which is shown below:
Can somebody shed some light on this problem. I have to submit this project so a timely reply will be highly appreciated.
Let one thing be very clear that I am only dealing with Revit linked cases. Waiting to hear from you soon.
John
Answered By 0 points N/A #86248
The image you have uploaded is a bit blurry and is not that much clear. Maybe putting the image again will clear the error type that you are getting. But I try to help you out with the most common error that mostly people get while working with this software.
When you export or import something you need to take care of all the preferences or the attributes that are being used in the images that you use so that they are not get distorted.
  1. First make sure that they are of the exact thing that you are going to use.
  2. Second, make sure that you are getting the things straight during the export thing because if you export well, you can import it good later.
