Exporting windows phone 7 memos exchange to formats like word document
How can I export windows phone 7 memos exchange messages to word document and other formats like pdf to allow for use in other devices and even in hosted environment like google docs?
Best Answer by Williams Todd
Answered By 0 points N/A #160095
Yes, You can do all these things on windows 7 phone. However Microsoft will release something big for office 365 enhancement. For now you have Microsoft share point, which enables you to share , Edit, Save, It comes with Microsoft office 365 in market, Microsoft market place. However it will requires network connectivity to work with share point, Thou you can work offline. Now I am giving you Microsoft office 365, Video sneak peak, It will help you to understand better
https://www.microsoft.com/en-us/
Thanks
Answered By 0 points N/A #160096
You will not be able to move the MemoPad application files to the Media Card. what you need to do is to synchronic them to your PC and Outlook via Desktop Manager, or you can choose to send tem to a CSV text file.  Here is what you have to do:
Check out Desktop Manager > Sync > Configuration. Then, look for the prompts to advanced > select your Memo Pad on the iPhone and the target of the sync.
You can also do the following:
1. Go to Memo pad
2. select the memo you want to transfer
3. press the Menu button on your BB
4. select Forward as
5. select Email
6. type your email address and send
I hope this is useful.
