Extending Active Directory schema Progress
Hi
I get the error message “Extending Active Directory schema Progress ……………………. FAILED Active Directory operation failed on mail.mydomain.com.jo” When I try to install exchange 2007 into windows 2008 Service pack 2 environments, where exchange 2003 Service pack 2 is installed is on the only DC.
The error mentioned above is not retainable, and the parameter is not correct.
The response from the active directory is: LdapErr: DSID-0C090A85, comment: Error in attribute conversion operation, data 0, vece.
Any form of help with this error will be appreciated.
