Extending chrome by CoolNovo 2.0.2.26
I’ve known about the CoolNovo’s newest version, which extends Chrome with some interesting additions. Is there any problem introduced along with these additions?
Hi there!
Actually, CoolNovo is formerly ChromePlus. It is Google Chrome with some additional cool features such as it has an “IE Mode”. This is useful when you go to a site that requires Internet Explorer. You just have to click the icon located in the address bar. And voila! You are now switched as if you are using the IE browser. But unfortunately, when you try to open an Internet Explorer tab directly, it doesn’t work. Another thing I noticed is that when you install CoolNovo, it automatically becomes your default browser without prompting you. But these are just minor problems which I know will be fixed in time.
CoolNovo is another brand of web browser that’s based on the same engine as with the original Google Chrome plus a bunch of useful new tools that will make it easier to use. The interface is very much alike with that of Google Chrome but with new features. You can close any tab by merely double-clicking on them.
You can also surf the web by means of mouse gestures as well as open links by dragging and dropping them. In the older versions like CoolNovo 2.0.2.25, the mouse gestures can’t be customized. This lack of configuration has been fixed in the latest version, CoolNovo 2.0.9.20. In the latest version, you can now create your own custom mouse gesture that you can enjoy while browsing the web.
It was formerly known as ChromePlus. It is also integrated with a download manager just like with Maxthon Cloud Browser though I’m not sure if it can also download videos from video streaming sites. Visit CoolNovo Browser 2.0.9.20 for the latest version.
