Hi!
I would like to ask few questions about Gigabyte P35X. What are the specifications of this laptop? How much is it in the market now? What are the pros and cons of this laptop? What are the materials used in developing this device? What are the specifications of the monitor? How long does it take before we need to charge the battery? What are the available connectors included with this laptop in its package? What are the software that can help me rescue the data if everything fail? Please provide me answer for this.
Thank you very much!
The extensive capabilities of Gigabyte P35X and its features
Solution 1:
Specifications:
1. OS: Windows 8.1
      Windows 8.1 pro
      Windows 7 Home Premium
      Windows 7 professional.Â
2. Display: 15.6" WQHD+ 2880×1620 Wide Viewing Angle LCD
           15.6" Full HD 1920×1080 Wide Viewing Angle LCD
3. System Memory: 4/8GB DDRIIIL 1600, 2 slots (Max 16GB)
4. Chipset: Mobile Intel® HM87 Express Chipset
5. Video Graphics: Intel® HD Graphics 4600
                 NVIDIA® GeForce® GTX 980M GDDR5 8GB
                 Supports NVIDIA® Optimus™ Technology
6. Storage: *Supports Quadruple-storage System
           128/256/512GB mSATA SSD
           128/256/512GB mSATA SSD + 500/750GB/1TB/2TB 2.5" HDD 5400rpm/7200rpm
           128/256/512GB mSATA SSD + 128/256/512GB mSATA SSD + 500/750GB/1TB/2TB 2.5"                HDD 5400rpm/7200rpm
7. Keyboard Type: Full-sized Auto-Adjusting Backlit Keyboard
8. Optical Disk Drive: Blu-ray Rewritable Drive with BDXL Support
                    Super Multi DVD RW
9. I/O Port: USB(3.0)*2, USB(2.0)*2, HDMI, D-sub, RJ45, Mic-in, Earphone-out (SPDIF), SD Card Reader, DC-in Jack, Mini DisplayPort
10. Audio: 1.5 Watt Speaker*2, Woofer speaker*1, Microphone, Dolby® Digital Plus™ Home Theater
11. Communications: LAN: 10/100/1000Mbps Ethernet
                    Wireless LAN: 802.11ac/b/g/n
                    Bluetooth: Bluetooth V4.0
12. Webcam: HD Camera
13. Security: Kensington Lock
14. Battery: Li-Polymer, 11.1V, 75.81Wh
15. CPU: 4th Generation Intel® Core i7 -4720HQ (2.6GHz-3.6GHz)Â
        4th Generation Intel® Core i7 -4860HQ (2.4GHz-3.6GHz)Â
        4th Generation Intel® Core i7 -4710HQ (2.5GHz-3.5GHz)Â
Solution 2: Download and install ACRONYS software to take up the backup.
