External Hard Disk drive repair software
Asked By 55 points N/A Posted on -
Hello Techyv User,
I am using Windows 8 on my office PC and I accidentally turned the External Hard Drive to Recovery Disk, How to overcome this issue. Will an External Hard Disk drive repair software help me to overcome this issue, Please suggest a solution.
Thanks in Advance,
Marvin M Calderon
Best Answer by Welch Sanger
Answered By 0 points N/A #167732
It is unwise that you do not have any backup copies of your data on an external hard drive. All hard drives will fail eventually so you should be prepared for that.
Now you can use software named R-studio. It will take approximately 15-20 hours to recover everything.
Hope this will help you.
Answered By 0 points N/A #167733
In such case what you can do is perform a quick format but that will as you know erase all your data and directory.
You can try partition recovery software.
You can download it from here.
EaseUS Partition Recovery, is a free and easy to use partition recovery software which recover lost partition. This is one of the best partition recovery software for you.
