External HDD’s properties, – Error window appeared
Yesterday when I was just looking up my external HDD’s properties, the following error window appeared.
At first I liked to consider that as a bug.
But from various forum postings I came to realize this is something with my Ubuntu 12.04 (64-bit). As I am not an expert I can’t fix it up.
Please help me.
There was an error while getting the sharing information
'net usershare' returned error 255: net usershare: cannot open usershare
directory/var/lib/samba/usershares. Error No file directory
Please ask your system administrator to enable user sharing.
        Close
Best Answer by May Jratr
Answered By 0 points N/A #148067
Hi Matthew,
It may be a bug, restarting your PC may solve this problem.
 If it did not work, then try to put this symbol ; instead of symbol in the portion-
"usershare owner only = False"
Now save it and restart Samba by using
I hope it will work.
Answered By 0 points N/A #148068
Hi Matthew Jamesy,
Hope that my message finds you well.
For me I don’t know if this will affect your applets, it is a different bug.
Make the directory as the following in sudo:
Sudo > mkdir > p > /var/lib/samba/usershares
Also please take a look on the following URL and see what people say with this experience:
Hope that this will help you.
Thanks,
