Extra key sequence error message
I've discovered an extra key sequence that came with the software certification which after looking at an identical line:
“http://www.robotstudio.com/forum/forum_posts.asp?TID=3113”
But it needs to be set up at the "Additional Options" area of the program develops. The issue now is that when I type in this key sequence I get the following error:
I've examined many times the key sequence which if it is joined wrongly says that it’s an incorrect key sequence. The error message above seems as though it allows the key sequence but cannot look for the appropriate product in the press pool. I have 5.14.02 completely set up on my program so how can I add whatever is lost from my press share to get this factor running?
If any of you have experienced about this situation, I would request to share the solution. Thanks to you in advance for your valuable time.
Error:
Add/Remove Additional Options The selected key is not used with any additional program in the current Media Pool. Please enter another key or browse for another key file.
