Extra RAM for PS4 possible?
Asked By 25 points N/A Posted on -
Hello! I bought my PS4 a few days ago and it has 500 GB ram already in it. I want to know if I can upgrade and get more RAM for my PS4. I know that 500 GB ram is too much but I still want to check if its possible to get extra RAM for my PS4. Thanks!
Answered By 0 points N/A #183783
The “PS4” has 500 GB internal memory when you buy it. There is no other way to add more memory internally to the “PS4”, and also you cannot extend your memory of the “PS4” by using external hard disk too.
It is not possible to add the memory internally and externally in the “PS4”. That’s why “Sony Developers” are now making the “PS4” up to 2 TB  internal memory.
 Hope this answer will help you a lot.
