Username
320 points
Posted on - 01/21/2013
I am a novice in dealing with SWF tools specifically "swf editor freeware". I find it very useful for updating or editing a lot of my flash applications. I'm not very familiar in the feature of swf editor freeware which involves extraction of audiotracks. How can I carry out this feature and what appropriate file formats can audio tracks be saved?
Extracting Audio tracks With swf editor freeware
Hello
You can do this by using SWF Riper. It is freeware application and it is capable of doing his task. This is how it looks like:
Only thing you need to do is to locate your swf file and this application will do all the work for you. It only supports mp3 files but since mp3 is most popular audio format it will be no problem for you.
You can download it from here:Â https://www.filecluster.com/howto/how-to-extract-mp3-from-swf-with-swf-rip/
Regards.
