Extracting DVD to Hard Drive
How can I copy the files from a DVD to my hard drive? The DVD is protected so what should I do?
Best Answer by Johnstoon Leen
Answered By 0 points N/A #143567
Copying protected DVDs are illegal because it would be considered as copyrighted. But there is software that can copy the file to your hard drive like “WinX DVD Ripper Platinum allows users to copy the newest protected DVD to hard. But make sure that your computer support multi-core CPU and fully compatible with windows 7.
Answered By 0 points N/A #196061
Hi Charles Mitchell
Copy Data from protected DVD to Hard Drive is not impossible, yet there are many ways to do this sort of things. I have found multiple ways to copy data from protected DVD to Hard Drive. There are many kind of software’s for this solution, these are listed below.
  1. Leawo DVD Copy (Recommended)
  2. Ripit4me
  3. DVDfabdecrypter
  4. Anydvd
And many more but I’ll recommend you to use “Leawo DVD Copy” due to many reasons
  1. It provides best solutions to solve this problem
  2. It can easily copy all data or specific data from protected DVD to hard drive
  3. It can copy DVD Discs from DVD9 to DVD5
  4. It has a powerful DVD copy Program
  5. It can also copy protected DVD Disc such as CSS-DVD Discs
I hope your problem will be resolve by doing this.
Johnstoon Leen
