I was talking to some friend the other days, about computer, and one of them mentioned Extreme Power Supply Calculator Pro.
Now, I didn't knew anything about this software, so I've done some research, but still can't figure if it is good for a computer or not.
Can you please explain to me, what are its features, and if it is good.
Basically what does it do for my computer?
Is eXtreme Power Supply Calculator Pro any good?
Hi,Â
    Well the pro version is a paid one and in order to utilize all the capabilities one need to install every component included and follow all the directions. But the free ones on the website are more than enough for normal users to know the power consumption. Generally it would be useful for people who perform R&D and need benchmarks for statistical data.Â
The Free version is sufficient for a brief idea about the power consumption of proposed new rig or build. However its also important to know how many Amperes your PC consumes in order to work efficiently without causing any harm to PC components. These parameters help to better configure the system with added-on-devices.So you might want to have the professional version for few bucks. Just go through the below figure for features comparison between free and professional version:
