Exynos 4412 – the man behind Samsung Galaxy S III
I read an article posted saying this device was made using the same process as the Apple A5 rev 2 is made,
any major functional distinction over units having either one of these processors?
The Apple A5 clocked at 1GHz can adjust its frequency to save battery life. It also includes an image signal processor unit that will do things such as face detection, white balance and automatic image stabilization and an earSmart for noise cancelling.
The Exynos 4412 on the other hand is clocked at 1.4GHz. It can also have the ability to switch off the whole core and scale both voltage and frequency. Samsung is claiming that it can go beyond 1.4GHz under scenarios that don’t utilize the four cores.
To conclude, Exynos has the upper hand when it comes to the clocking of the processor.
Hope you will find this helpful.
Cheers
The Samsung Galaxy S III Smartphone is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled and released on May 2012. It measures 136.6 x 70.6 x 8.6 millimeters and weighs 133 grams. It uses micro-SIM card. It has Super AMOLED capacitive touchscreen display with 16M colors at 720 x 1280 pixels screen resolution.
It supports multi-touch protected by Corning Gorilla Glass 2 with TouchWiz UI support. It comes with either Android 4.0.4 Ice Cream Sandwich or Android 4.3 Jelly Bean powered by Exynos 4412 Quad chipset, Quad Core 1.4 GHz Cortex-A9 processor, and Mali-400MP4 GPU. It supports microSD expandable up to 64 GB.
It runs on 1 GB RAM with internal storage available in the following capacities: 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.6, autofocus, and LED flash. The primary camera features 1/3" sensor size, geo-tagging, touch focus, and face and smile detection and can record video in 1080p at 30 fps.
The secondary camera supports 1.9 megapixels with f/2.6 and can record video in 720p at 30 fps. It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, and aptX support; GPS with A-GPS and GLONASS support; NFC; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support.
It has built-in accelerometer, gyro, proximity, compass, and barometer sensors. The pre-installed web browser supports HTML with Adobe Flash support. It doesn’t support Java. It runs on removable Li-Ion 2100 mAh battery with standby time up to 590 hours on 2G and 790 hours on 3G. Talk time is up to 21 hours 40 minutes on 2G and 11 hours 40 minutes on 3G.
It is available in pebble blue, garnet red, sapphire black, la fleur, marble white, titanium grey, and amber brown colors. Here are the differences between the Samsung Exynos 4 Quad (4412) chipset and the Apple A5 (APL0498) chipset:
