EZ Calendar Widgets APK download
I saw EZ Calendar Widget from one of my friends Android phone, but I don’t know from where he got EZ Calendar Widgets APK Download, Please guide me to find it.
Hi Morison,
In order for EZ Calendar Widget to work, you must have EZ Launcher. Both apps are available for free on Google Play.
Firstly, install Ez Launcher. After you installed it, install EZ Calendar Widget.
Now on your Android home screen, tap and hold your finger on any blank area of the screen. An “Add to Home screen” window will pop up. From that window, tap “EZ Widgets”. Select EZ Calendar Widget from the list and you should have your cool widget.
Hope this helps you.
