EZoom GPS Locator estimated distance range and setup costs
Can anyone tell me what is the distance range within which the EZoom GPS Locator can be used for functioning?
Please also tell me about the necessary setup costs.
eZoomGPS has an accuracy of 15 yards that’s equivalent to 45 feet, approximately 11.5 meters. the tracker has excellent features as 21 days long low maintenance battery life in standby mode as well as unlimited on demand location details. The GPS Vehicle Tracker can be mounted on bicycle, motorcycle or can be installed on motor vehicle. If you want to install on a vehicle you may choose to by the gadget at USD 99.99 and an auto installation kit for USD 24.99 totaling to USD 124.98. For free use or for mounting on a bicycle or motor cycle you can buy the gadget at USD 99.99, the charger at USD 19.99 and a pouch at USD 14.99 totaling to 134.97.
Hello Corin,
This GPS tracking device uses continuous tracking to give you the automatic updates of your current location every 5 minutes for up to 1 hour. Its location history will make it possible for you to see where your gadget has traveled for the past hour, day or week.
The technology it uses is the Assisted GPS technology (A-GPS), which utilizes both satellite as well as cellular technologies to help more precisely as well as reliably determine the location of where the GPS tracker is at. As for its cost, you can find it at a cost of $199.99 $189.00, but the price may range depending on where you are buying it.
Carl
Notifications
