Walter Neff
30 points
Posted on - 09/17/2012
When I had windows XP I installed F1 2012 Steam without any difficulty. Recently I upgraded to windows 7 and tried reinstalling but now CD key won’t work. I used the same key which I used for XP. Does anybody know if it has something to do with up gradation from XP to 7? Any kind of help would be appreciated.
F1 2012 Steam CD Key won’t work for Windows 7.
Hello.
Your F1 2012 Steam is the version compatible with windows xp.
The version of F1 2012 Steam which you are using is not supported with windows 7.
You have to download the latest version of F1 2012 Steam in order to I stall it on windows 7.
Click on the below link to download and know more about F1 2012 Steam.
http://store.steampowered.com/app/208500/
Thank you.
Hello Walter Neff,
Your CD Key might be used up. As far as I know, it has a limit on how many times you can use a CD Key to prevent piracy. You should try to contact the game developer's technical support and tell them this problem. They might be able to help you with your problem.
Hope this helps.
