F1 problems with boot PC
Posted on - 01/02/2012
Hi Experts,
Every time I start my PC it’s require to press F1 key. I check it in the setup of computer but I can’t find from where disable it. My question is that how for what propose it is used in startup and how to fix this problem, means how to remove the option of pressing .
