Facebook account is disable and taking no command on Google chrome
I download Google chrome and set it as my default browser. But my Facebook account is disable and taking no command on Google chrome. What is the problem? Why does my Facebook account halt on Google chrome while it is active on Firefox?
Answered By 0 points N/A #155522
Usually chrome is faster browser than any others and I’m using it for long time. But if you can’t access Facebook on google chrome it might be your configuration problem, please make sure no sites are blocked on your chrome. As well as clear all of your browsing history, temporary files, cache and cookies. On the another way you may uninstall the browser and reinstall it. I think it works. But if you can’t access your facebook account from any other browser please go the following address:
https://www.facebook.com/help.
Otherwise please tell us the message what showing on your monitor.
Thanks
Answered By 590495 points N/A #315962
I don’t think there’s a problem with Facebook on Google Chrome because this website opens fastest on Google Chrome as with my experience. If you can’t log in to your Facebook account on Google Chrome, make sure you are using the latest. Uninstall and update to the latest version. Download the free version of Revo Uninstaller and install it.
Once installed, start Revo Uninstaller then select Google Chrome among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the latest Google Chrome browser.
This link downloads the standalone installer. If the problem continues, try using other browsers like SeaMonkey, Opera, and Mozilla Firefox.
