Hi there,
I have downloaded Facebook Application and disabled sync since I don't want my contacts filling up with acquaintances contacts and email addresses, but every time I want to post a comment, the application will delay launch requesting I allow sync, how can I work smoothly with this app to sync disabled?
Facebook Application insists on Sync
Hi Gabrielleriya,
The steps through which Facebook application works with sync are as mentioned below:
1) Log out of the Facebook account running in the system
2) Go to the Apps list in the settings list and locate the Facebook application
3) Click 'Clear Cache' and 'Clear Data' folder in the list of folder
4) Navigate to the 'File manager' option, go to the SD card and internal storage of the device
5) Click on the 'Android folder', select 'Data folder' from the application
6) Delete the folder 'com.facebook.user' from the folder option
7) Restart the device and run the Facebook application
