Dan Brown
20 points
Posted on - 07/31/2011
Recently I found a new chat application in Ovi Store and from the past few weeks I was searching for this kind of application.
The chat application is Facebook chat and I downloaded the Facebook chat application from the Ovi Store.
But after installation whenever I try to log in, an error just pops up: "Login Failed: Login failed with current settings.
Reason: Login Failed".
Anyone have a solution of this?
sibabu
5 points
FaceBook Chat is not working on Nokia X3-00
For using internet in any mobile or pc/laptop,keeping default is best and if try to get new application it must be remind about that connection.some of new version software can not support and can not recognizes in using operator.therefore you must be install in any chatting,video calling,voice calling software based on mobile/pc/laptop/net book background.so keep existing default programme.keep happy.
Thanks
I read your problem and thought of sharing some views and experiences that might help you with this problem. So you are using Nokia X-3 and the Facebook chats isn’t working on your phone. Well to help you out with this I would like you to go to https://www.nokia.com/en_int and check whether your phone is registered or not to use this software. If not you really don’t need to worry about it, I have another procedure to help you out.
Please visit wap.getjar.com and download either (ebuddy) or (Nimbuzz) applications from the site. After downloading the application the program will automatically start by itself, and installation will start in your phone. Please follow the instructions as the applications require and hopefully you can install the program on your phone. Now that you have any one of them installed in your phone please start the application and sign up for that particular account’s program. After doing that you can go to the settings and can add your Facebook, Hotmail, yahoo, Gmail, etc all from a single program.
I would recommend you to use this program because they are compatible with any kind of phone and you won’t face any kind of problem using it. I hope the instructions I have given were helpful to you, and if you face any problem please don’t hesitate to ask me again, I would be very grateful to help you again with any kind of solution in this sector.
Thanks
