I have brought a new Android phone of Samsumg Galaxy Y, I need to install Facebook connect application on my phone, where should I download it for free. Please provide me the link for original application as I heard that there are chances for having spy version of that. So please provide me a trustable link to download. Thanks
Facebook connect application for my Android phone
Hello Friend,
You can easily install Facebook on your galaxy y s5360. Just follow given steps and you will be able to use Facebook from your Android phone. The steps are given below.
1. First of all you need to go ‘play store’ icon from your home screen and if you will not find they play store then Go to “Application“ icon and here you will see the option “play store”.
2. After that you need to go to “search” icon which will be on your upper right side of the screen, then type “Facebook” in the search and enter.
3. The third step is that “Facebook for Android” must should appear after your search so you have to locate it in your search and tap the install button, after that you need to read the agreement and tap the download button which will be at your upper right side.
4. The last step is open it and enter your email address and password and you are ready to use it.
There is a website from which you can download this application.
Hope this will help you.
First, you go to the Google Play for Facebook Connect application. You will see a lot of Facebook applications. For all of them, select your favorite Facebook application. All of these application links are free. Then, you press the Install button. A pop-up window will open that says “Login to Download”. You can login here with your Gmail ID. After you login, a pop-up window will open again, and you just press the OK button to download. They you will be able to download the software and install it. This way, you can connect to the Facebook application on your Samsung Galaxy Y.
