Facebook get an email when i receive a like
Is it possible to set in FB that i receive an email for each like i may get?
Also, an email for every unlike?
I believe you are connecting your Facebook to your email address. By default, all Facebook activities you perform will be notified via the email you connected your account to.Â
To fix this, go to Facebook. Click the gear icon at the upper right corner then go to Account settings.
Under Account settings, click the Notifications link. The third section on the upper left control panel.Â
Under Notifications, go to Email section.
Click Important notifications only so you will no longer receive unnecessary notifications.
Below the panel, you can also edit the notifications you receive.
This should fix the issue then.
