What is fbapierrordomain error code “368?” I can’t send a message on messenger and I keep receiving this message whenever I try to send one. What is it all about? Sometimes I can send messages and sometimes I cannot and this error pops up.
“Send failed
(#368) The action attempted has been deemed abusive or is otherwise disallowed”
Error code “368” in Facebook messenger or the “fbapierrordomain error 368” is a Facebook messenger error that doesn’t allow you to send a message or even attachment to your friends on Facebook. There are a couple of reasons that can trigger this error:
Spam messages
Technical difficulties
Storage space issue
Check the Facebook guidelines if you are sending messages, images, and videos or attachments to make sure your messages are not considered spam. You may also receive this error when one of your contacts marked your messages as spam or you are trying to send the same messages to too many people.
If you encounter this error when sending a message using the Facebook messenger app, wait about thirty (30) minutes before sending another message. If this doesn’t work and or you haven’t sent many messages, try restarting your phone. Press the power button on your phone then select “Restart.” If this doesn’t work, try updating the Facebook messenger app.
If this doesn’t work, delete the app on your phone then download it again on the Google Play store. If the problem continues, check that your phone’s internet connection is working. If you are connected to the internet via Wi-Fi, try restarting the Wi-Fi router. If the router has a power button, press it to turn it off then unplug it from the power for about twenty (20) seconds.
Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. When the router is ready, connect your phone again then see if it works.
1....
