FaceBook program transport error (#1001)
I need help!! Something is wrong with my facebook! I keep getting this error when I click my profile page
No Network
Transport error (#1001) while retrieving data from endpoint '/ajax/inline_comments.php': A network error occurred. Check that you are connected to the internet.
This only happens when I click my profile page. I tried clicking other stuff around and it’s all working.  Is there anybody here that can help me get rid of that annoying error message?
Best Answer by dainna
Answered By 0 points N/A #83371
Hi John Mason.
The solution is very simple just go through these steps below:
1. On the right side their is option tab click this and press privacy settings, then select application button, go to the setting tab, uncheck all the options there and save your new settings.
2. Either Refresh your existing page.
3. Or Log out and then log on back in again.
Hope this will work.
Answered By 0 points N/A #83373
Hi, John Mason
This problem is not very heard problem. It is very simple problem.
You can solve this problem.
You can do this that, you go to your Facebook right side,
Then click the option.Then click privacy setting and uncheck all.  Then log out your Facebook and then log on.Then your problem has gone.
