Hi There!
I used Facebook in past years. Facebook is the main largest social communicating website for all. We like Facebook.
Also we want to protect our Facebook account.
So I thought that, If I change my security setting and use third party options for protecting my account then my account will be more secure.
So I start using uprotect. It plugins. After installing new uprotect.
It plugins I lost my an important Facebook app.
I cannot remove it from my Facebook app list.
Because it does not show app list.
How can I remove it?
FaceBook security question please help me
This app makes your Facebook account secured but since you want to remove it, I will show you how to remove. Just follow the steps below;
* Open your browser, go to Facebook.com website.
* Log-in with your email address and password.
* Once Logged in, click on Account tab in the right hand corner.
* Then choose Privacy Settings.
* Click on Edit your settings for games and websites.
* You'll see the app link to your account, then click on remove app.
* A box will ask you to confirm, then say yes and that should be it.
This will remove the app on your Facebook account.
You will need to use the following procedure to remove the uprotect. It plugins from your Facebook account:
First, you will need to open your Facebook account, that is, you will have to be logged on to your Facebook account.
And then you will need to go to the Privacy settings which you will find in the Account tab. See image below for more guidance:
And then you will need to click on the Edit your setting for using applications, games and websites. See the image below for guidance on where to find that option.
And then finally, you will need to locate the list of applications that have been linked to your account. You should check to see if there are any unwanted connections, and then click on Edit application and then Remove app as shown below:
Lastly, you will need to click on the Remove option in the confirmation box to remove that application.
Clair Charles
