Facilities of creating more drives in Hard Disk
What are the facilities of creating more drives instead of keeping only C drives in Hard Disk of computer?
Hello Dilton.
To create multiple drives in one hard disk, you need a partition manager. Â There are many freeware partition managers that can do what you want without costing you a cent. Â Below are some of the free partition management software that have been tested and thoroughly reviewed by PC enthusiasts the world over:
1. Minitool Partition Wizard Home Edition (https://www.partitionwizard.com/free-partition-manager.html)
2. Paragon Partition Manager Free Edition (https://backstage.paragon-software.com/free/pm-express/#resources)
3. GParted (https://gparted.sourceforge.io/)
4. EASEUS Partition Master (Home Edition) (https://www.partition-tool.com/personal.htm)
The above partition managers can perform the jobs to create, move, delete, resize, and format partitions. Â These partition operations can be done without losing any existing data.
Hope this helps!
Hi Drey,
It is a good question. Everyone should know this. If you keep only C drive you have to save all files into c drive. But, the main problem is, when you will go to set up your laptop or PC you have to set it up in c drive. You need to format to install it.
Then all your files & data’s will be removed.
That is the main reason to create more drives.
