Facing to create a countdown clock for a forum post
Hello all,
I am creating a WordPress site. This site is mainly blog related and will be used for forum posting. But I am having a problem here. I want to add a countdown clock for a forum post. But I cannot add the Countdown clock. Can anyone help me and tell me how can I add a countdown clock in a forum post in my WordPress site?
Thank you.
Best Answer by Cameron Msjamie
Answered By 0 points N/A #166324
So If you want to add countdown clock then follow the Steps.
1. Open http://www.countdownclockcodes.com/
2. Choose any Countdown Clock as you want.
3. Set the Date for your Event, Set Skin and Type your Message.
4. You can see the Embed code of this Widget. Just copy the Code.
Now You have to add the codes to your blogger blog.
5. Open your blogger account and Open your blog Dashboard.
6. Click Layout.
7. Click Add a Gadget.
8. Add/Select HTML/JavaScript Gadget from Gadget box.
9. In the content Section Just Paste those code.
10. Save
Answered By 5 points N/A #166323
Hi Motton
I’ve been developing WordPress websites for over a year now and in order to make a countdown timer, you must have a successfully installed countdown timer plugin. Here is the direct download link for this plugin. I am using that tool when I am creating posts that requires countdown timers. You can also use that countdown as a widget, and with the use of short codes.
Its version is 3.0.5  which supports 22 languages.
Here is the screenshot to prove that it is really working on posts.
I hope this answer will help you in developing your WordPress website.
