Facing Error 0x80070091 Windows 7 Directory Empty
I was trying to transfer the data from one location to another, but I am facing error 0x80070091 Windows 7. It is giving empty directory error. Please help me with this.
Make sure when you solve the error, you are logged in as an administrator
Alternatively, you can use Microsoft Safety Scanner. It is available free.
If you cannot delete a particular folder because it is corrupt even if you have administrative privileges, one method you can try is to delete the files inside the corrupt folder one by one until you see which file is causing the folder not to be deleted. Though this is possible but it is actually not practical if the folder contains huge number of files.
Another way is to delete the folder in Safe Mode. Restart your computer and press F8 before the Windows logo appears. In “Advanced Boot Options,” select “Safe Mode” then hit Enter. In Safe Mode, open Windows Explorer and navigate to the corrupt folder and delete it. See if it works. If this failed to work, another way is to rename the folder.
Select the corrupt folder and press F2 to rename. Name it as without quotes “$Recycle.Bin” then empty the Recycle Bin. After this, the folder should be deleted automatically.
Notifications
