Facing Error Code 300 While Watching Netflix On Sony TV
I was using Netflix on my Sony TV, and suddenly Error Code 300 appeared on the screen. Can you please tell me some solution for this error?
The error occurs while you are trying to watch Netflix on Sony TV or Blu-ray player. The error occurs because there are some issues in the communication services of the Sony.
Solution 1:
Try to restart the app and then access the movie or the TV show you want to watch on the Netflix.
Solution 2:
If solution one does not work, then you have to wait for some time, as there may be congestion in the Network that is generating the error.
If you are watching Netflix and you encounter error code “300”, see if you are watching Netflix on a Sony TV or Blu-ray player. This error code usually points to a communication problem with Sony’s services. If ever you encounter this error code while watching Netflix on a Sony TV or Blu-ray player, try selecting the “Retry” option on the screen.
Doing this will restart the app. Once the app finishes restarting, try Netflix again. If this doesn’t work, try waiting for a few minutes before trying Netflix again for any network congestion to clear up. If this doesn’t work and the problem continues, Netflix recommends that you contact Sony for further assistance.
