Facing Error Code MS2105 While Trying To Access Netflix
I am not able to watch movies or shows on Netflix. When I am connecting to Netflix, it is displaying Error Code MS2015 on the screen.
This error occurs because of one of the following reason –
Solution 1:
Try to use another browser for watching shows or movies on the Netflix.
Solution 2:
Re-install the Silverlight plug-in. It is readily available on the internet.
Open control panel and choose an option to install or uninstall a program.
Uninstall Silverlight from the list of programs that appears on the screen.
Solution 3:
If no solution mentioned above works, try to troubleshoot the problem, the system will automatically detect the error and solve them.
