Hey everyone,
I have downloaded archicad free converter from a website, but i get this error often "Cannot save Plan file".
Do you guys think I got this error because it's a free version? It is very strange because sometimes I can save it and sometimes I get this error .
Help me please as this error irritates me always.
Thanks
Facing error while saving file in archicad free converter
Hi Rodney B Hunter,
You already mention that you are using the free version of the software. At first you should know that is it totally free? Or you are using the trial version of that.
If you are using a trial version then it is ok. Trial version of a software will not be working properly the main cause is they made these types of software for users to check before they purchase.
If it is totally free then you can uninstall that and reinstall again. If it persists further then there are some bugs in that software.
Have a good day
