Hello guys, I am getting some error while trying to install Autodesk design review 2008. It says, “Runtime Error 2738.
Could not access VBScript run for custom action”.
I also attached the screen shot of this error:
Facing Installation problem of autodesk
The main root of this error "runtime Error 2738.Could not access VBScript run for custom action" means the VBScript engine is not registered on the device where the install or uninstall process is taking place. The first and the most important thing you could do is to is to register VBScript.
You could do this by running the Command Prompt as administrator. Go to the Start Menu, then click on the All Programs, after which is Accessories then right click on Command Prompt and then select Run as administrator. Choose on which to run the following command:32-bit version of Windows(Type cd %windir%system32 into the Command Prompt and hit Enter);64-bit version of Windows; (Key in cd %windir%syswow64 into the command prompt and click Enter). The last thing to do is to type regsvr32 vbscript.dll into the command prompt and hit Enter.
