Facing IPhone Restore Error 3194 While Updating
I am trying to update my phone, but it is showing iPhone restore error 3194. How can I fix the problem in some simple steps using the Windows?
The below-mentioned steps describe how to solve the error using hosts:
If you receive error code 3194 when restoring your iPhone, try this method that worked for some users. If your phone is currently connected to your computer via the USB cable, turn off your iPhone and disconnect the cable from the phone while the other end of the cable is still connected to the computer.
While your phone is off, press and hold the Home button and connect the USB cable to your phone. Keep holding the Home button until iTunes pops up. This should enter your phone into force recovery mode. Using iTunes, try updating your phone by following the instructions. See if this works. Before doing this, make sure you have the latest iTunes installed.
Visit Download iTunes to get the latest.
